SS-V: 6000 Simply Supported Thin Square Plate - Harmonic Forced Vibration Response
Test No. VD01 View transient response of a simply supported square plate subjected to harmonic forced vibration.
Definition
- ω=2∗PI∗fω=2∗PI∗f
- ff
- Excitation frequency.
The excitation frequency changes in range from 0 to just above first resonant frequency of the plate.
Sixteen (16) modes are used to approximate dynamics solution and 2% modal damping is assumed in all modes.
- Properties
- Value
- Modulus of Elasticity
- 2.e+11 Pa
- Poisson's Ratio
- 0.3
- Density
- 8.e+3 kg/m3
Results
Deflection Y, mm | Surface Stress, MPa | |
45.34 | 31.86 | SimSolid, solid model |
45.42 | 35.08 | Reference, thin plate model |
